Hi, I am sri.sagar's friend & I am doing the actual design.
Thank you all for your replay..
1st In the above Image, I just simulated a small design with 2 inverters coded in VERILOG-A since I am new to it. Now I know the process that how to do with Verilog-A using Cadence Spectre tool.
Hi @geoffrey_Coram, I just followed the procedure in that link (tutorial) & tried to do with a small inverter program. I followed the steps correctly, Now I am able to simulate.
Hi Ywguo, till now I didn't start with the design of LDO.
Hi despap, Yes, you r right I used the "Spectre" as simulator other than "SpectreVerilog"(as shown in that tutorial). & in View Name I have selected "Schematic" So that now I am able to run any of my Verilog-A codes..
![Smiley Smiley](https://designers-guide.org/forum/Templates/Forum/default/smiley.gif)
Now I am going to start with the Actual Design of LDO. I really don't know how to start coding the Verilog-A for LDO.??
Do I need to write the code according to the circuit?? or only for the Equations of gain. load regulator etc..??
Can anyone Help me in this regard. Thanking you.
