Aug 15th, 2024, 10:32pm
Transient Methods in cadence (Read 2774 times)
afridi
Feb 07th, 2012, 10:17pm
What is the difference in Transient solver methods such as "gear2only" "trap" etc. Can anyone share a good explanation and comparison of their characteristics for required type of analysis.
The more things you do, the more you can do.(Lucille Ball)
boe
Re: Transient Methods in cadence
Reply #1 - Feb 8th, 2012, 4:01am
Afridi,
These are algorithms to solve O(rdinary) D(ifferential) E(quations) numerically.
You can find explanations in any textbook on numerical methods for ODEs. Look for second-order Gear algorithm (gear2), trapezoid (or Crank–Nicolson) method (trap), or backward Euler (euler). The other options are combinations of these options.
- B O E
afridi
Reply #2 - Feb 8th, 2012, 5:07am
Okay thank you. I will definitely look into that.
But isnt there any non-mathematical explanation and comparision of such algorithm in terms of what kind of numerical technique is it, its advantages and its disadvantages in the Cadence documentation or any other open source documentation. For example, SILVACO TCAD has a whole chapter in its help file on the numerical techniques it is using and what are the pros and cons of each solving technique. etc etc
Frank Wiedmann
Munich, Germany
Reply #3 - Feb 8th, 2012, 5:52am
Take a look at Ken's book "The Designer's Guide to SPICE and Spectre" (see http://www.designers-guide.org/Books/#Kundert-1995).
