Jul 18th, 2024, 12:32am
verilogA: how to print out number with parametric precision? (Read 7551 times)
Irvin73
Israel
Mar 06th, 2012, 3:35am
I want to print out some data from my verilogA code. Let's say for this task I'm using code like:
$strobe("Conversion value: %6.2f (LSB)",counter_value);
and get this response as expected: Conversion value: 700.00 (LSB)
But the question is, how can I print with parametric precision? I mean if I want change the number of digits after point according to parameter, there is a way to do it?
Following straight forward approach (create the pattern string first dependent on parameter, then strobe it) doesn't solve the problem:
parameter integer intPrecision = 2;
string strPattern;
strPattern= $sscanf("Conversion value: %%6.%df (LSB)",intPrecision);
$strobe(strPattern,counter_value);
I get output like: Conversion value: %6.2f (LSB)  700
It means $strobe function behaves in different way for these two cases for some reason. Any suggestions about possible solution?
Thanks in advance.
Re: verilogA: how to print out number with parametric precision?
Reply #1 - Mar 6th, 2012, 10:41am
I don't recall seeing support for variable field widths in Verilog, but since the simulator generally translates Verilog to C and compiles the C into object code, did you try something like
$strobe("Conversion value: %*.*f (LSB)", 6, 2, counter_value);
Irvin73
Israel
Reply #2 - Mar 7th, 2012, 11:00am
Hi Geoffrey,
Thanks for your response. Unfortunately,  when trying your suggestion, I got the compilation error:
Encountered unexpected in percentage format command, '*'. Use a valid percentage format command and try again
Because for practical resasons the number of different values for precision digits is small (say 1,2,..6), I simply used the "case" statement workaround, like:
case(1)
    (intPrecision == 1) :  $strobe("Conversion value: %6.1f (LSB)",counter_value);
    (intPrecision == 2) :  $strobe("Conversion value: %6.2f (LSB)",counter_value);
    (intPrecision == 3) :  $strobe("Conversion value: %6.3f (LSB)",counter_value);
    (intPrecision == 4) :  $strobe("Conversion value: %6.4f (LSB)",counter_value);
    default                  $strobe("Conversion value: %6.1f (LSB)",counter_value);
endcase
Of course it is so nasty (especially if you have a lot of $strobe or $fwrite statements!), but it works.
If anyone will share some magic trick to solve it in clean way, it will be good news. Meanwhile I continue with this workaround.
Thanks again for your response Smiley
