Jul 16th, 2024, 12:35pm
Regions of operation of transistors in cadence (Read 3241 times)
gido
Mar 08th, 2012, 12:04pm
      I would like to know what regions 1, 2 ,3 and 4 stand for in cadence!!
Forum Administrator
YaBB Administrator
Re: Regions of operation of transistors in cadence
Reply #1 - Mar 8th, 2012, 11:59pm
Presumably when you say Cadence, you mean Spectre. If so, then you can run 'spectre -h devtype' where devtype is the type of the device you are interested in. Look for the region parameter. It will list out all known regions in order. I believe 1 is the first entry.
