Hi!
![Smiley Smiley](https://designers-guide.org/forum/Templates/Forum/default/smiley.gif)
Usually, corners for mos, resistors, diodes, etc are placed in one file.
But if I use links to one model file for different devices in my “pcf” (ADE corners file), is doesn’t work… For solution this problem, i generate new file for each device. Is very ugly…
![Angry Angry](https://designers-guide.org/forum/Templates/Forum/default/angry.gif)
What I should do... Thanks!
For example, what I do…
;pcf file
;corners definition for 0.60um process
corAddProcess("060um" "/space/home/eboyarinov/" 'multipleModelLib)
corAddModelFileAndSectionChoices("060um" "TS06/tsl060.scs"
'( "typical5v" "slow5v" "fast5v" "up5v" "down5v" )
corAddModelFileAndSectionChoices("060um" "TS06/passive_model06/tsl060_ggnmos.scs"
'( "typical5vgg" "slow5vgg" "fast5vgg" )
corAddModelFileAndSectionChoices("060um" "TS06/passive_model06/tsl060_resistors.scs"
'( "typ_resd1" "high_resd1" "low_resd1" )
corAddModelFileAndSectionChoices("060um" "TS06/passive_model06/tsl060_diodes.scs"
'( "diodes" )
corAddCorner("060um" "typ_25"
?sections '( ("TS06/tsl060.scs" "typical5v" )
("TS06/passive_model06/tsl060_ggnmos.scs" "typical5vgg" )
("TS06/passive_model06/tsl060_resistors.scs" "typ_resd1")
("TS06/passive_model06/tsl060_diodes.scs" "diodes")
?runTemp 25
?nomTemp 25 )
