Jul 18th, 2024, 8:37am
Stack Memory verilog program- need help please (Read 2917 times)
sivashankarvela
Mar 19th, 2012, 1:13pm
Following is my verilog program for stack memory. I am able write it in Stack but not able to read it from that. Please help me in this.
//module
module stack(clock,reset,remove,insert,data_in,data_out,error_read,error_write);
input clock,reset,remove,insert,data_in;
/*remove - the signal to enable the read operation
data_in - variable to write the data into the stack
insert - signal to enable the write operation
data_out - variable to read from the stack
error_read - This signal will be high when the stack is empty and the data is tried out to be read
error_write - This signal will be high when the stack is full and the data is tried to be written*/
wire [7:0] data_in;
output [7:0]data_out;
output error_read,error_write;
reg [1:0] cstate,nstate;
reg error_read,error_write;
reg [7:0] stack_reg [7:0];
reg [7:0] data_out;
reg [2:0] write_buff; // for write operation
/* parameter [1:0] idle=2'b00,
               write=2'b01,
               read=2'b10,
               error=2'b11; */
reg [2:0] read_pointer,write_pointer;
reg [2:0] read_address,write_address,write_bufaddress;
integer i;
always@(posedge clock or negedge reset)
begin
    if(!reset)
    begin
        for(i=0; i<8;i=i+1)
           begin
            stack_reg[i] <=8'h00;
           write_pointer<=3'h0 ;
           read_pointer<=3'h0;
           write_buff <= 0;
           error_read <= 0;
           error_write <= 0;
   cstate <= 0;
else
       begin
           cstate <= nstate;
         write_buff <=write_pointer;
//$display("state");
always@(remove or insert or cstate or data_in)
begin
nstate = 2'b00;
error_read=0;
error_write=0;
write_pointer=0;
data_out = 0;
case(cstate)
2'b00: begin
        if((insert==1) && (write_buff !=7))
        begin
                nstate = 2'b01;
 //               $display("It is in idle state");
    else if((insert==1) && (write_buff==7))
       begin
             nstate = 2'b11;
   else if((remove==1) && (write_buff !=0))
       begin
             nstate = 2'b10;
    else if((remove)  && (write_buff==0))
        begin
              nstate = 2'b11;
   else
   begin
       nstate = 0;
2'b01: begin
     stack_reg[write_buff] = data_in;
     write_pointer= write_buff+1;
     nstate=2'b00;
2'b10: begin
     read_pointer = write_buff-1;
     data_out =stack_reg[read_pointer];
    nstate=0;
2'b11: begin
     if((insert) && (write_buff > 8))
     begin
       error_write=1;
   else if((remove) && (write_buff == 0))
    begin
      error_read=1;
   nstate=2'b00;
endcase
module test_stack;
reg [7:0] data_in;
reg reset,clock,insert,remove;
wire error_read,error_write;
//wire [7:0] stack_reg [7:0];
wire [7:0] data_out;
stack in_stack(clock,reset,remove,insert,data_in,data_out,error_read,error_write);
initial
  $vcdpluson;
initial
begin
   $monitor("reset=%b, data_in=%h, insert=%b,remove=%b, data_out=%h,error_read=%b,error_write=%b",reset,data_in,insert,remove,data_out,e
initial
 begin
clock=0;
forever #5 clock=~clock;
initial
begin
#5 reset=1; insert=0; data_in=0;remove=0;
#10 reset=0; insert=0;data_in=0;remove=0;
#10 reset=1; insert=1;data_in=011;remove=0;
#10 reset=1; insert=0;data_in=0;remove=1;
#10 $finish;/*
#10 reset=1; insert=1;data_in=2;remove=0;
#10 reset=1; insert=1;data_in=3;remove=0;
#10 reset=1; insert=0;remove=1;
#10 reset=1; insert=0;remove=0;
#1000 $finish;*/
