Jul 18th, 2024, 10:24am
How to get a Gaussian source using Verilog-AMS (Read 1670 times)
ahutianyi
Mar 22nd, 2012, 1:25am
Hi,guys
I'm modeling a ADC.However,I meet a problem when to model a random source.I need a 255 outputs Gaussian source,and I find it difficult to realize that using "$rdist_normal(seed,mean,deviation)". Cry
Is there anybody who can help me?
Thanks very much!
ahutianyi
Re: How to get a Gaussian source using Verilog-AMS
Reply #1 - Mar 23rd, 2012, 12:56am
ahutianyi wrote on Mar 22nd, 2012, 1:25am:
Hi,guys
I'm modeling a block.However,I meet a problem when to model a random source.I need a 255 outputs Gaussian source,and I find it difficult to realize that using "$rdist_normal(seed,mean,deviation)". Cry
Thanks very much!
Reply #2 - Mar 23rd, 2012, 7:09am
What do you mean when saying 255 outputs Gaussian source? What do you get using your code?
Is it correct for the code
V(offset[i]) <+ V(result[i]);
result is defined as real. I don't know what the compiler/simulator do with the above statement.
Yawei
Reply #3 - Mar 26th, 2012, 10:46am
I'm sure he meant
V(offset[i]) <+ result[i];
Reply #4 - Mar 26th, 2012, 10:52am
But I think you need two integers, one for the loop index and a second for the seed; as it is,
 V(offset[1]) = $rdist_normal(1, mean, dev)
That is, the call to $rdist_normal that sets output[1] is always made with the seed=1, so it will get the same value for each and every timepoint.
ahutianyi
Reply #5 - Mar 27th, 2012, 5:01am
I meant that I want to get a series of random sources.All the sources follow the Gaussian distribution.I found the sytax error---V(offset[i])<+V(result[i]).However,I can't realize the resources yet.Is there anybody can help me?
Reply #6 - Mar 27th, 2012, 11:07am
We can't help you if we don't understand what you are trying to do.
Are you sure you want a new $rdist value for *every* timepoint?
Perhaps you want to use a clock input, or a timer event, to signal when to generate new random values.
integer i, myseed;
genvar j;
@(initial_step)
 myseed = 0;
@(timer(0,1u)) begin
 for (i=1; i <=256; i++) begin
   result[i] = $rdist_normal(myseed, mean, dev);
for (j=1; j <=256; j++) begin
 V(offset[j]) <+ transition(result[j], 0, 1n, 1n);
ahutianyi
Reply #7 - Mar 27th, 2012, 11:47pm
Thanks a lot.I'm sure I want to realize a series of Gaussian voltages,and the voltages are stable.I use these voltages as the sources of the latter blocks. Smiley
Reply #8 - Mar 28th, 2012, 4:53am
Oh, if the voltages are stable (ie, don't change in time, but are picked randomly at time zero), then
integer i, myseed;
genvar j;
@(initial_step) begin
myseed = 0;
V(offset[j]) <+ result[j];
