Polux
Hello all and thank you for the help.
Apparently in ICCAP using spectre simulator in mode ads ( a type of simulator that can be choosen in the program called spmodeads) gives compilation problems when we use initial conditions. In order to avoid that problem, instead of using intial conditions, I used a nand gate in the first stage of the ring oscilator, se we can have an extra pin to estimulate the oscilation. Now it works fine.
Thanks again for the concern,
