nzborsti
Hello to everyone,
I am new to Verilog AMS and Cadence Virtuoso and so I do have quite a few problems to get started. Maybe someone is able to help me with this one:
I wrote a simple verilog ams code for a low pass filter which includes the following line:
parameter real nst_0=1 [0:inf);
I managed to create a schematic and a config file so that I was able to run an ac analysis in ADE XL. Now I want to run the same analysis again but this time I want to have the parameter "nst_0" listed under "local variables" (on the left in the Virtuoso ADE XL window) so that is easy to change the value for this paramter.
I already tried to assign a string " nst" to the value of "nst_0" in the "edit Object Properties" Window. After that I added a Design Variable in the Virtuoso ADE XL window named "nst" and assigned a value to this variable. But this didn't do the job cause everytime I hit the simulate button a error comes up:
ncelab: *E,CUBSPA (./netlist.vams,22|22): Assignment of string to real or integer type parameter.
Another try was to use the "Copy from" button which comes up when you click on "add local variable" but nothing happend.
Has anyone an idea how to get this job done?
Kind regards
