Jul 2nd, 2025, 5:02am
ADE XL create local variable from verilog ams code... (Read 3438 times)
nzborsti
Apr 05th, 2012, 8:46am
Hello to everyone,
I am new to Verilog AMS and Cadence Virtuoso and so I do have quite a few problems to get started. Maybe someone is able to help me with this one:
I wrote a simple verilog ams code for a low pass filter which includes the following line:
parameter real nst_0=1 [0:inf);
I managed to create a schematic and a config file so that I was able to run an ac analysis in ADE XL. Now I want to run the same analysis again but this time I want to have the parameter "nst_0" listed under "local variables" (on the left in the  Virtuoso ADE XL window) so that is easy to change the value for this paramter.
I already tried to assign a string " nst" to the value of "nst_0" in the "edit Object Properties" Window. After that I added a Design Variable in the Virtuoso ADE XL window named "nst" and assigned a value to this variable. But this didn't do the job cause everytime I hit the simulate button a error comes up:
ncelab: *E,CUBSPA (./netlist.vams,22|22): Assignment of string to real or integer type parameter.
Another try was to use the "Copy from" button which comes up when you click on "add local variable" but nothing happend.
Has anyone an idea how to get this job done?
Kind regards
Re: ADE XL create local variable from verilog ams code...
Reply #1 - Apr 13th, 2012, 8:20am
I stumbled into similar problem not only with ADE-XL, but also with ADE-L. Cry
boe
Reply #2 - Apr 16th, 2012, 8:55am
did you search the forum?
- B O E
nzborsti
Reply #3 - Apr 20th, 2012, 6:10am
I have been looking quite a while but so far no success. Any one out there who is able to help????
thx
boe
Reply #4 - Apr 20th, 2012, 12:34pm
last year, we had a discussion about this here...
- B O E
nzborsti
Reply #5 - Apr 23rd, 2012, 1:56am
thank you very much for pointing me in the right direction. But for somereason I couldn't find the right thread. Can you please give me a link....
thx
boe
Reply #6 - Apr 23rd, 2012, 2:33am
Searching for the error message CUBSPA finds the thread
http://www.designers-guide.org/Forum/YaBB.pl?num=1297252828.
- B O E
nzborsti
Reply #7 - Apr 23rd, 2012, 2:41am
thx
nzborsti
Reply #8 - Apr 26th, 2012, 12:28am
thank you BOE for the link, it really helped me a lot to get closer to the solution and now it works -> problem solved.
All I had to do is to use the CDF toll , open each "cell" as "base" and enable the "parse as number" option. After that I could easily add the design variables in ADE XL and had no errors coming up.
