Aug 16th, 2024, 7:43pm
How to set up and simulate a switched-capacitor CMFB? (Read 2556 times)
Jacki
Apr 16th, 2012, 10:11am
  I am simulating a switched-capacitor amplifier, it is the simple and typical fully differential SC-amp, with the gain of 2. At the beginning, I use continuous CMFB, it works well. Now I am trying to use SC-CMFB as shown in the book (by Paul R. Gray), but I always have the problem of converge for both Trans. and PSS simulation. Then the simulation is crashed.
  I am using Spectre, in transient simulation, I set the "skip dc", I use "gear2only", also I set ic "all".
   Does anybody have the experience about simulating SC-CMFB?
   Thank you.
boe
Re: How to set up and simulate a switched-capacitor CMFB?
Reply #1 - Apr 16th, 2012, 10:24am
Jacki,
A simulator crash is a tool bug.
- B O E
Jacki
Reply #2 - Apr 17th, 2012, 9:17am
Hello Boe,
   Thank you for your reply.
   I solve the problem, because I am using the ideal switch from analogLib, I set the on-resistor and off-resistor as the default value, that is crazy. Now I change them to the reliable one. Spectre works.
   Jacki
