Jul 20th, 2024, 12:35am
hspice: to plot .meas results (Read 3455 times)
leo-samba
Apr 26th, 2012, 7:11am
Hi, I'm doing a transient analysis of my circuit in hspice and measure its current exactly at 1us with several values of an additional parameter:
.param aaa=...
.tran ... sweep aaa ...
.meas tran iii find i(...) at=1u
The results in the .mt0 file are correct to the first extent.
Then I'm trying to plot the resulting current with this parameter value in the x-axis:
.print tran par('iii') ...
, but I can't get a normal graph in the viewer, I only obtain a bar chart, like this:
iii
------------------------------------------ aaa
The final points of these bars are just the points I need. How to do the analysis correctly, or plot the points correctly, so as to get a normal graph?
Thanx.
spiceoracle
USA
Re: hspice: to plot .meas results
Reply #1 - May 31st, 2012, 1:48pm
Which waveform viewer are you trying to use?
oermens
Reply #2 - Jun 3rd, 2012, 9:04pm
I believe you can use Synopsys WaveView to evaluate HSPICE measure statements and plot them graphically.
spiceoracle
USA
Reply #3 - Jun 4th, 2012, 1:19pm
Yes, if you are using WaveView, you can display the information correctly.
