leo-samba
Hi, I'm doing a transient analysis of my circuit in hspice and measure its current exactly at 1us with several values of an additional parameter:
.param aaa=... .tran ... sweep aaa ... .meas tran iii find i(...) at=1u
The results in the .mt0 file are correct to the first extent. Then I'm trying to plot the resulting current with this parameter value in the x-axis:
.print tran par('iii') ...
, but I can't get a normal graph in the viewer, I only obtain a bar chart, like this:
iii | | | | | | | | | | | | | | | | | | | | | ------------------------------------------ aaa
The final points of these bars are just the points I need. How to do the analysis correctly, or plot the points correctly, so as to get a normal graph?
Thanx.
