Raja,
Try opening the Results Browser, then selecting dcOpInfo for the desired device select the dc operating point parameter you would like and send it to the Calculator. Repeat for the opposite polarity device.
Example: Results Browser: dcOpInfo --> NM0 --> gm, see selectgm.tif
Also attached is an example of the plotting the sum of a pch and nch gm, see plots.tif
