vivkr
I usually use spectreMDL for running my batch jobs and make use of MDL's ability to process signals to generate various scalar outputs or run searches.
Now, I have found that MDL expressions are not recognized when I create a measurement alias for a PSS analysis, although the analysis itself is run.
Does anyone know of a way around this?
I suspect that MDL expressions are not directly supported as PSS analysis actually comprises different sub-analyses, such as the initial TRAN until stabilization of the PSS and time- and frequency- domain analysis performed within PSS.
Any tips would be welcome.
Regards, Vivek
P.S: There are very good reasons why I do not use ADE-XL or expressions directly out of the ADE-L GUI. So, kindly do not suggest using one of these.
