Jul 18th, 2024, 10:32am
verilogA: Connecting different regulator on same node. (Read 877 times)
fabian
Europe
May 11th, 2012, 1:32am
Hi All,
I do not know if I am using the right methodology at the moment to model in verilogA a complex regulator built with Series and Shunt regulators. My view is to develop a verilogA model for each of them.
Following this method, I need to have a high impedance out model for the disable regulators.
So I have defined an internal regulated signal,
 electrical int_out, out;
 inout out;
 V(int_out, gnd) <+ slew(vout,5e6);
and I am defining the output impedance such as
 if (reg_en)
    res=1m;
 else
    res=1G;
 V(int_out,out) <+ I(int_out,out) * transition(res,0,1u);  (line 63)
When I run the simulation I got the following message:
"... near line 63: Encountered illegal use of both the potential and the flow of a pure probe branch (supply_gnd). Use either the potential or the flow of a pure probe branch, but not both."
Does someone see an obvious error on this code?
I am using this modelling for switch and it works fine?
Best regards,
Fabian
Re: verilogA: Connecting different regulator on same node.
Reply #1 - May 11th, 2012, 8:02am
Your error message talks about "supply_gnd" but I don't see that it in the code snippets you posted.
fabian
Europe
Reply #2 - May 11th, 2012, 9:14am
Thanks for your reply. Here is the code and I hope it is less snippet.
What I am not getting is that I would like to use the modelling of a switch for the branch b_supply but does not allow me to use I(b_supply) in function of v(b_supply)?
Could you recommand me a solution?
Fabian
`include "constants.vams"
`include "disciplines.vams"
module shunt_reg(supply, enable, gnd);
	inout supply;
	electrical supply;
	input enable, gnd;
	electrical enable, gnd;
	parameter real param_vth 			= 500m;
	parameter real param_vreg_snk		= 1.8;
	parameter real param_vmin		= 1u;
	real loadres, vout, res_supply;
	integer reg_en;
	electrical int_supply;
	branch (int_supply, supply) b_supply;
	analog begin
		reg_en = (V(enable, gnd) > param_vth);
		// Model the shunt regulator.
		loadres = (I(supply, gnd)==0) ? 1 : -1 * (V(supply, gnd)/I(supply, gnd));
		loadres = transition(loadres, 0, 1u);
		if (loadres >= 0)
		begin
				vout = param_vmin;
		else
		begin
			if (reg_en)
				vout = param_vreg_snk;
			else
				vout = param_vmin;
		V(int_supply, gnd) 	<+ slew(vout,5e2);
   	if (reg_en)
			res_supply = 1m;
   	else
			res_supply = 1G;
		V(b_supply) <+ I(b_supply) * transition(res_supply,0,1u);
The error message is:
Error found by spectre during AHDL read-in.
   ERROR (VACOMP-2077): "...shunt_reg/veriloga/veriloga.va", near line 49: Encountered illegal use of both the potential and the flow of a pure probe branch (supply_gnd). Use either the potential or the flow of a pure probe branch, but not both.
   ERROR (VACOMP-1816): Exiting AHDL compilation.
   ERROR (SFE-91): Error when elaborating the instance shunt_reg. Simulation should be terminated.
Reply #3 - May 14th, 2012, 5:28am
If I combine these two lines:
where b_supply is the branch between int_supply and supply, then you've (indirectly) specified the voltage between supply and gnd.
This line:
is probing both the voltage and current in that branch, without specifying any constraint on them from within the model.  Typically, if you want to measure a current, you are measuring the current through a short -- and then it doesn't make sense to be simultaneously measuring the voltage.
Also, on the next line:
you're mis-applying the transition function to a continuous waveform.
I don't know what the "loadres" is supposed to be doing, but you need a different way to figure it out.
