Thanks for your reply. Here is the code and I hope it is less snippet.
What I am not getting is that I would like to use the modelling of a switch for the branch b_supply but does not allow me to use I(b_supply) in function of v(b_supply)?
Could you recommand me a solution?
Fabian
Code:`include "constants.vams"
`include "disciplines.vams"
module shunt_reg(supply, enable, gnd);
inout supply;
electrical supply;
input enable, gnd;
electrical enable, gnd;
parameter real param_vth = 500m;
parameter real param_vreg_snk = 1.8;
parameter real param_vmin = 1u;
real loadres, vout, res_supply;
integer reg_en;
electrical int_supply;
branch (int_supply, supply) b_supply;
analog begin
reg_en = (V(enable, gnd) > param_vth);
// Model the shunt regulator.
loadres = (I(supply, gnd)==0) ? 1 : -1 * (V(supply, gnd)/I(supply, gnd));
loadres = transition(loadres, 0, 1u);
if (loadres >= 0)
begin
vout = param_vmin;
else
begin
if (reg_en)
vout = param_vreg_snk;
else
vout = param_vmin;
V(int_supply, gnd) <+ slew(vout,5e2);
if (reg_en)
res_supply = 1m;
else
res_supply = 1G;
V(b_supply) <+ I(b_supply) * transition(res_supply,0,1u);
The error message is:
Error found by spectre during AHDL read-in.
ERROR (VACOMP-2077): "...shunt_reg/veriloga/veriloga.va", near line 49: Encountered illegal use of both the potential and the flow of a pure probe branch (supply_gnd). Use either the potential or the flow of a pure probe branch, but not both.
ERROR (VACOMP-1816): Exiting AHDL compilation.
ERROR (SFE-91): Error when elaborating the instance shunt_reg. Simulation should be terminated.
