diegochi
Hi to everybody! I want to model a Mos transistor using a table model. I've saved my data in an external file "dati_mos.txt". Then I recall it with the instructions: Code:parameter string model_file = ".\dati_mos.txt";
I(D,S) <+ $table_model(V(G,S), V(D,S), model_file, "3L,3L");
When I compile it, an error occour: In file /home/xxx/xxx/xxx/table_model.vams line 27: I(D,S) <+ $table_model(V(G,S), V(D,S), model_file, "3L,3L"); ^ [Error] Unknown system function $table_model Error: (valog) Compilation: Analysis failed.How can I resolve it? Many thanks!
