Jul 18th, 2024, 6:22am
Verilog-A table model (Read 4446 times)
diegochi
May 21st, 2012, 4:07am
Hi to everybody!
I want to model a Mos transistor using a table model. I've saved my data in an external file "dati_mos.txt".
Then I recall it with the instructions:
parameter string model_file = ".\dati_mos.txt";
I(D,S) <+ $table_model(V(G,S), V(D,S), model_file, "3L,3L");
When I compile it, an error occour:
In file /home/xxx/xxx/xxx/table_model.vams line     27:
[Error] Unknown system function $table_model
Error: (valog) Compilation: Analysis failed.
How can I resolve it?
Many thanks!
Re: Verilog-A table model
Reply #1 - May 21st, 2012, 1:48pm
It looks to me that your simulator doesn't support $table_model.
You can check with your support representative, or try a different simulator.
