Jul 19th, 2024, 6:30pm
weird pnoise waveform, advise needed (Read 2082 times)
subgold
May 29th, 2012, 1:13am
I have got a strange noise spectral density plot from a pnoise simulation. Please see the attached picture:
The blue curve is a typical simulation which looks normal, while the red curve is the result at one specific corner, which shows a big fluctuation and looks doubtful.
Could somebody give a clue about what is going on at that strange corner? (i am using cadence version ic6.1.5), thanks.
Re: weird pnoise waveform, advise needed
Reply #1 - May 29th, 2012, 9:08am
Are you sure your PSS converged fully?
raja.cedt
Reply #2 - May 29th, 2012, 12:05pm
check how PSS result looks like??? Even before try to run transient sim in that corner, i guess some thing wrong with that corner
