Aug 15th, 2024, 12:37pm
Transimpedance amplifier (Read 4839 times)
Muhammed
Jun 14th, 2012, 4:40pm
Hello all ..
I design TIA using CG topologies with current source .. but i don't knew how to simulate it in cadence ... i did not find any port supply current
Anyone found current port in cadence please tell me .. thanks in advance
aaron_do
Re: Transimpedance amplifier
Reply #1 - Jun 14th, 2012, 9:41pm
What do you mean by current port? For a current source, you can use isin from analogLib....
Aaron
Muhammed
Reply #2 - Jun 14th, 2012, 9:44pm
yes i knew isin .. but in noise analysis you cannot perform it unless there is a port .. so i am asking about current port ???
I found large amount of noise about 50dB thermal noise which is not reasonable so i am asking about how i could do it right
RFICDUDE
Reply #3 - Jun 15th, 2012, 4:24am
Are you just simulating the TIA by itself?
If so, then you should be able to use "noise" analysis where an input port is not explicitly needed.
If your results are not what you expect, then it is probably a good idea to double check the simulation bench set up or look at the noise contributor summary to see which devices are contributing the most noise at the output. Perhaps this will help you debug why the noise is not what you expect or like.
Muhammed
Reply #4 - Jun 15th, 2012, 8:16am
my noise setup test bench ....
i put port instead of isin .. then balun to give me the differential input
and i made it dc source not sine
is that right ?? i want to calculate NF so cadence told me i should put port but this port is a voltage port not current port ... so is this result right ??
thanks for your replying Smiley
