Aug 15th, 2024, 12:37pm
Question about output current in VerilogAMS (Read 7558 times)
urian
Jul 24th, 2012, 9:57pm
Hi,there
I have written a module in AMS, which output a current corresponding with the input binary code as follows:
module (Iout, Ain);  //Iout is output current,and Ain is 2bits input.
    output Iout;
    input [0:1] Ain;
    electrical Iout;
    logic [0:1] Ain;
    parameter real I = 6E-9; //unit current
    real iout; //internal current variable;
    always @(*) begin
	 case (Ain)   //decide the iout from Ain
	    2'b00: begin iout = 5.0; end
	    2'b01: begin iout = 4.0; end
	    2'b11: begin iout = 3.0; end
	    2'b11: begin iout = 2.0; end
	  endcase
     analog
	   I(Iout) <+ iout*I;//generating output current base on iout and I
When compiling the module, it gives a error message which shows that "I(Iout) <+ iout*I" has error with "illegal expression primary".
I dont know why and how to fix it, any suggestion will be appreciated.
urian
Re: Question about output current in VerilogAMS
Reply #1 - Jul 25th, 2012, 1:57am
Your module has not any module name.
Please do NOT define parameter I because this is an access function for electrical node. Then the error message "illegal primary expression" disappears.
Yawei
« Last Edit: Jul 25th, 2012, 3:03am by ywguo »
urian
Reply #2 - Jul 25th, 2012, 8:45am
Thanks Yawei , you are right,the error has been fixed. Then what's the meaning of "illegal primary expression"?
Best regards
urian
Reply #3 - Jul 25th, 2012, 7:47pm
Hi urian,
In section 7.3.6.3, VerilogAMS LRM 2.3.1, it reads that an analog primary (variable, potential, or flow) whose value is ....
In section 7.3.6.5, VerilogAMS LRm 2.3.1, it reads that a digital primary (reg, wire, integer, etc.) whose value is ....
Obviously variable, potential and flow are primary in analog context, and reg, wire, integer, etc. are primary in analog context.
In your module, I is defined as a parameter. It results in illegal primary expression because I is access function of flow in verilogAMS.
Yawei
urian
Reply #4 - Jul 25th, 2012, 9:39pm
Thank you,Yawei ,I get it!
When I writting the module, I am confusing with the output current and voltage relationship.As in my module,there is only current output, then what about the port voltage?How does the module decide it?
When I using the module, I find that it makes the CMOS transistor which tied to it go into triode region.I wonder how to avoid it and accurate define the output relationship between current and voltage? Is it because my module is so simply?
urian
Reply #5 - Jul 26th, 2012, 5:35am
urian wrote on Jul 25th, 2012, 9:39pm:
From the Spice solver's point of view, you've defined an ideal current source.  The module/current source doesn't decide the voltage; the solver applies the current and then tries to solve all the node voltages to satisfy Kirchoff's Current Law.
urian
Reply #6 - Jul 28th, 2012, 3:49am
Hi,Geoffrey_Coram.So my module is just a ideal current source and its port voltage is determined by outside network.
And I find another problem.When I use "ground gnd" to declare a ground node and use it in "V(a,gnd)" statement, it said the gnd has not been declared.Is something wrong?
urian
Reply #7 - Jul 31st, 2012, 6:45pm
Hi urian,
Did you declare that gnd is electrical node? In Section 3.6.4, verilog-AMS LRM,
Quote:
Each ground declaration is associated with an already declared net of continuous discipline. The node associated
with the net will be the global reference node in the circuit. The net must be assigned a continuous
discipline to be declared ground.
Yawei
urian
Reply #8 - Aug 1st, 2012, 8:15am
Hi,ywguo, I did not declare the gnd as electrical node. I have seen in the book "THE DESIGNER’S GUIDE TO VERILOG-AMS", there is example code as below:
//A simple circuit
`include “disciplines.vams”
`include “vsrc.vams”
`include “resistor.vams”
module smpl_ckt;
electrical n;
ground gnd;
vsrc #(.dc(1)) V1(n, gnd);
resistor #(.r(1k)) R1(n, gnd);
so I dont know it should be electrical. When refer to LRM, I have fixed this error as you said.Thanks a lot!
urian
Reply #9 - Aug 1st, 2012, 10:28am
My mistake. Sorry about that.
