Jul 30th, 2024, 7:23am
monte carlo trimmed simulation in adexl (cadence 6) (Read 2109 times)
tempora123
Aug 01st, 2012, 7:16am
Does anyone know how to setup monte carlo simulation under adexl in such way that:
- 1st test bench uses tran smulation to find a trimming code for a particular instance (DUT)
- 2nd test bench uses dc temp sweep to run a monte carlo trimmed simulation
In both test benches DUT should contain devices with the same mismatch spread on their model parameters.
Thanks for your help.
