tempora123
Does anyone know how to setup monte carlo simulation under adexl in such way that: - 1st test bench uses tran smulation to find a trimming code for a particular instance (DUT) - 2nd test bench uses dc temp sweep to run a monte carlo trimmed simulation In both test benches DUT should contain devices with the same mismatch spread on their model parameters.
Thanks for your help.
