Jul 16th, 2024, 8:26pm
Sample and Hold without Hidden State but with External Clock Input (Read 4215 times)
mardukeyo
Aug 17th, 2012, 11:33am
Below is a version of Sample and Hold Model with External Clock Input That functions in Cadence Virtuoso Transient Simulation properly. I have simulated it with Cadence PSS and PAC, and  the simulator does not complain of any hidden states. However, the PAC simulation result does not generate the sinc function frequency response and instead simply has no out put (zero).
Can someone give me some hints on how to go about debug this??
Marduke
`include "disciplines.vams"
`include "constants.vams"
//  Sample & Hold with Extrernal Clock and No Hidden State
module SH_NHS_EXCLK (pout, nout,clk,pin, nin);
   input clk, pin, nin;
   output pout, nout;
   electrical clk, pin, nin, pout, nout;
   parameter real clk_thresh =  1/2 from (-inf:inf);
   parameter integer clk_dir =  1 from [-1:+1] exclude 0;
                                   // if dir=+1, rising clock edge triggers
                                   // if dir=-1, falling clock edge triggers
   parameter real tclkd = 10p from [0:inf);            // output delay (s)
   parameter real trf   = 10p from [0:inf);            // output transition time (s)
   real out;
   integer sampleNow;
   analog begin
       sampleNow=0;
     @(initial_step or cross(V(clk) - clk_thresh, clk_dir))
           sampleNow=1;
       out = idt(0,V(pin,nin),sampleNow);
     V(pout,nout) <+ transition( out, tclkd, trf,trf );
Frank Wiedmann
Munich, Germany
Re: Sample and Hold without Hidden State but with External Clock Input
Reply #1 - Aug 19th, 2012, 3:35am
mardukeyo
Reply #2 - Aug 21st, 2012, 10:07pm
Thank you Frank, that site did help me understand the issue better...
