Jul 17th, 2024, 11:31am
Problem on monte carlo statistic block? (Read 1727 times)
Yutao Liu
Guangzhou, China
Aug 19th, 2012, 1:26am
Hello everyone,
 What does "dist=gauss std=1/1" means in statistic block? I found this in a TMSC model file. The standard deviation value should be a absolute value or a percentage according to spectre userguide, right?
Best,
Yutao Liu
Re: Problem on monte carlo statistic block?
Reply #1 - Aug 24th, 2012, 6:39am
I have a model file from a different foundry that sets std=1/3 or std=mc_std/3
I assume these are expressions that resolve to simple numbers, but in the latter case, the user can perhaps set how many standard deviations.
