Jul 17th, 2024, 8:18pm
verilog ams ADC model with PSS (Read 4174 times)
conr
Sep 26th, 2012, 12:56am
I have designed a very simple ADC model in verilog AMS. it works with dc and tran analysis but not with PSS. Anyone know why it happens and how to fix it? It is a problem of PSS analysis or something related to verilog AMS events?
analog begin
     @(initial_step("dc")) begin
         if (dc_value==`LIMIT) begin
             dc_calc=V(vin)/vref*`LIMIT;
       else begin
           dc_calc=dc_value;
       mod[0]=dc_calc%2;
       div[0] = dc_calc /2;
       for (i = 1; i <= (`NUM_ADC_BITS-1) ; i = i + 1) begin
       mod[i] = div[i-1]%2;
       div[i] = div[i-1]/ 2;
       V(vd7) <+ mod[7]*vlogic_high;
         V(vd6) <+ mod[6]*vlogic_high;
         V(vd5) <+ mod[5]*vlogic_high;
         V(vd4) <+ mod[4]*vlogic_high;
         V(vd3) <+ mod[3]*vlogic_high;
         V(vd2) <+ mod[2]*vlogic_high;
         V(vd1) <+ mod[1]*vlogic_high;
         V(vd0) <+ mod[0]*vlogic_high;
Re: verilog ams ADC model with PSS
Reply #1 - Sep 27th, 2012, 12:24pm
When I read this model, it looks like all the contributions (V(vd7) <+) are done inside the @initial_step block.
I can't imagine how this model works at all, because these contributions do not persist after the first step.  If you sweep (dc) or ramp (tran) the input, I don't see the module doing anything after the first point.
conr
Reply #2 - Sep 28th, 2012, 12:44am
Hi Geoffrey,
many thanks for your reply.
I did a mistake coping the verilog model inside the topic. the real model had also a second section for transitorial analysis:
@ ( initial_step("tran") ) begin
         halfref = vref / 2;
     @ (cross(V(vclk) - vtrans_clk, 1)) begin
        unconverted = V(vin);
        for (i = (`NUM_ADC_BITS-1); i >= 0 ; i = i - 1) begin
           vd[i] = 0;
           if (unconverted > halfref) begin
              vd[i] = vlogic_high;
              unconverted = unconverted - halfref;
         end else begin
              vd[i] = vlogic_low;
           unconverted = unconverted * 2;
     // assign the outputs
     V(vd7) <+ transition( vd[7], tdel, trise, tfall );
     V(vd6) <+ transition( vd[6], tdel, trise, tfall );
     V(vd5) <+ transition( vd[5], tdel, trise, tfall );
     V(vd4) <+ transition( vd[4], tdel, trise, tfall );
     V(vd3) <+ transition( vd[3], tdel, trise, tfall );
     V(vd2) <+ transition( vd[2], tdel, trise, tfall );
     V(vd1) <+ transition( vd[1], tdel, trise, tfall );
     V(vd0) <+ transition( vd[0], tdel, trise, tfall );
The problem was the initialization of the variable halfref done just for "tran" simulation. I added "pss" in the initial_step function and now it works also for pss analysis.
Reply #3 - Oct 1st, 2012, 6:30am
I try to avoid initial_step for reasons such as this: you don't want to have to specify every possible analysis.
A simple division is not much work, even if the simulator does it every iteration.  Many compilers will optimize this away so that it only gets executed once.
Alternately, you could use
 localparam halfref = vref / 2;
