Dec 7th, 2025, 11:11am
pss simulation running out of memory (Read 3799 times)
analog2000
Oct 13th, 2012, 9:56am
I have a switched cap block (about 2000 xstrs and capacitors) that I am trying to simulate. After about a few minutes of pss (shooting method, conservative setting) simulation I run out of memory.
Any suggestions on how to run pss simulations with this many xstrs ?
thanks
analog2000
Re: pss simulation running out of memory
Reply #1 - Oct 15th, 2012, 5:42am
Sometimes I come accross "out of memory", not only for the simulator. Please try to run the simulation with 64 bit tools. Probably it is spectre -64bit. I am not sure. Please look for spectre online help.
Yawei
