Jul 16th, 2024, 1:37am
measuring mosfet parasitic caps cgs,cgd in AC simulation. (Read 6307 times)
yvkrishna
Nov 03rd, 2012, 9:04am
I am trying to create a testup for measuring cgd,cgs etc.
(ofcourse they are available in DCOP, here idea is to use this setup for a new composite device)
using AC=1 at gate of a mos and finding the imaginary part of the current gives the cap loading at that node, but how to find the junction caps cgd,cgs only?
tried using 'sp1tswitch' from analogLib but was not successful.
can someone please help with a simple test setup for measuring them in any simulation.
yvkrishna.
Maks
San Jose
Re: measuring mosfet parasitic caps cgs,cgd in AC simulation.
Reply #1 - Nov 29th, 2012, 12:00pm
Apply AC signal to the gate, and measure the AC current at the nodes you are interested in (source, drain, bulk,...) - you will get the respective capacitive coupling components you are interested in. The sum of them should be equal to the total gate capacitance.
yvkrishna
Reply #2 - Nov 30th, 2012, 7:57am
Thats not so simple, how do you eliminate the effect of other caps like cgd,csb which come in series/shunt while doing this experiment?
Maks
San Jose
Reply #3 - Dec 12th, 2012, 11:03pm
yvkrishna wrote on Nov 30th, 2012, 7:57am:
I don't think so.
In an N-port system - apply an AC signal to port i, and ground all other ports. The AC current through port j (its imaginary part) will give you Cij component.
