Jul 17th, 2024, 8:23pm
current limiter (Read 6382 times)
fgcsk
current limiter
Nov 20th, 2012, 12:22am
I just wrote a current limiter. It works but the result is a little bit strange.
`include "constants.vams"
`include "discipline.vams"
module current_limiter(in,out);
inout in, out;
electrical in, out;
parameter imax = 3e-3;
analog
begin
if(I(in,out) >= imax && V(in,out) >= 0)
        I(in,out) <+ imax;
else
        V(in,out) <+ 0;
Given the input voltage(top fig.) and a series resistor, the current(bottom fig.) limits at 3mA. But I don't know why the current is somewhat distorted before it reaches the limit?
Thanks.
boe
Re: current limiter
Reply #1 - Nov 20th, 2012, 3:22am
fgcsk,
Most likely, this is a plotting artefact caused by widely-spaced simulator time points.
By the way, your implementation is not recommended. A better implementation can be found at http://www.designers-guide.org/VerilogAMS/
- B O E
fgcsk
Re: current limiter
Reply #2 - Nov 20th, 2012, 7:09am
boe wrote on Nov 20th, 2012, 3:22am:
fgcsk,
- B O E
Above is .tran 1us 32us
Even if I change it to .tran 0.01us 32us, it still have the same problem:
Re: current limiter
Reply #3 - Nov 20th, 2012, 11:19am
If you want to resolve the corners you will need to add a cross function. If you have access to my book on Verilog-AMS, I recommend you take a look at sections 6.2 and 6.3 (page 71-73).
fgcsk
Re: current limiter
Reply #4 - Nov 20th, 2012, 1:03pm
Ken Kundert wrote on Nov 20th, 2012, 11:19am:
I've tried that. But it doesn't solve the problem. Cry
Actually I think the problem doesn't happen right at corners.
boe
Re: current limiter
Reply #5 - Nov 20th, 2012, 2:50pm
If you want to resolve the corners you will need to add a cross function. ...
Ken,
the model is a limiter, so it should never cross the limit.
- B O E
Re: current limiter
Reply #6 - Nov 20th, 2012, 5:44pm
Both Boe and I are trying to point you to the answer without having to spend a lot of time trying to explain a somewhat confusing topic. So, you should look at the model that BOE pointed you to (the current limited voltage regulator on the Verilog-AMS page) and if you do not understand it you should read the section of my book that I pointed you to.
« Last Edit: Dec 5th, 2012, 8:06am by Ken Kundert »
fgcsk
Re: current limiter
Reply #7 - Nov 28th, 2012, 12:07am
I finally solved this problem.
Here's the code:
`include "disciplines.vams"
inout in, out;
electrical in, out;
analog
begin
@(cross(I(in,out)+V(in,out)-imax,0))
if(I(in,out)+V(in,out) > imax)
	I(in,out) <+ imax;
else
	V(in,out) <+ 0;
By using a way similar to the diode model(p73, Ken's book), I cut on a diagonal in the IV plane and get the condition: I(in,out)+V(in,out) > imax, then the problem could be solved.
But I still don't know why I should not cut twice as before: I(in,out) >= imax && V(in,out) >= 0. Does it cause convergence problems?
thanks.
boe
Re: current limiter
Reply #8 - Nov 28th, 2012, 2:44am
fgcsk wrote on Nov 28th, 2012, 12:07am:
Yes. If the model is in current limit mode and (e.g. due to rounding errors) the current gets slightly smaller, the original model immediately shorts the terminals whatever the voltage across the limiter.
- B O E
fgcsk
Re: current limiter
Reply #9 - Nov 28th, 2012, 8:32am
boe wrote on Nov 28th, 2012, 2:44am:
- B O E
Could you illustrate this more detailedly?
Didn't get it Huh
boe
Re: current limiter
Reply #10 - Dec 5th, 2012, 4:46am
fgcsk wrote on Nov 28th, 2012, 8:32am:
Didn't get it Huh
I'll try. For example: Suppose you are at V(in,out) = 1 Volt and I(in, out) = imax. Then the model should use the current path. If I(in,out) now changes to imax-ε due to numerical errors, your first model jumps to V(in, out) = 0 creating a discontinuity.
This discontinuity is not only wrong (in this case), but can also cause convergence difficulties.
- B O E
