RolfK
Dear Experts,
I would like to trigger a curent wave by some event. The event could by a kind of clock signal or an abstract verilog named event.
My questions is a conceptual one. In case I would use a table model like shown below, I could imagine to assign it to a signal. The constant inputs are MIN|TYP|MAX (as enumerator 0,1,2) and the current simulation dtime (time - the start time of this process ). This way I hope the simulator interpolates the current given by the table dependent on simulation time. This is quite similar to a PWL. BUT, I do not know how to start a PWL on some event and additinally it looks very benefitial to me to have the option of more consatnt parameters in one table.
Here is some PSEUDO CODE snipet: analog @(starting event) begin start_time = 0 ; always(@ $current_time ) begin dtime = $current_time - start_time ; I(p,n) n <+ $table_model (TYP, dtime , "iwave.tbl", "?,?,?") ; end end end
######### table file ######################### // Look up table for i(t) 2d with time // Index mtm time current 1 0 0 0 2 0 1.00e-12 0.1 3 0 2.00e-12 0.3 4 0 10.00e-12 0.05 5 1 0 0 6 1 1.00e-12 0.15 7 1 2.00e-12 0.35 8 1 10.00e-12 0.06 9 2 0 0 10 2 1.00e-12 0.2 11 2 2.00e-12 0.4 12 2 10.00e-12 0.07
If there is some alternative or better idea I wopuld like to learn about it. Additionally I need to learmn more about the control string. I had a look into the Cadence Verilog-A Reference model, but did not find an exhaustive explantion there.
Thanks a lot
RolfK
