Jul 17th, 2024, 1:21pm
Verilog-A compilation error (Read 1240 times)
Deadok
Nov 23rd, 2012, 5:00am
Dear All,
I have a Verilog-A model of a transistor.
I built a super simple test bench in cadence and tried to run a simulation.
Netlist was built successfully, however the error appeared during the compilation phase:
Error found by spectre during AHDL read-in.
   ERROR (VACOMP-1008): Cannot compile ahdlcmi module library. Check the log file ***/ahdlcmi.out for details. If the compiler ran out of memory, use 'setenv CDS_CMI_COMPLEVEL 0', and try again. If the reason for the failure was a syntax error, contact your Cadence Customer Support representative with the netlist, log files, behavioral model files, and any other information that can help identify the problem.
In the ahdlcmi.out file I may several lines like this:
Compiling C file InGaAs_NMOS_func.c (optimize) with -O0
***/bin/gcc  -march=k8 -ffast-math -O0 -m64 -DSYSV -DSVR4 -D_REENTRANT -fPIC   -DconfigSPECTRE -I. -I/***/cadence/release2012/mmsim_v11.10.366/tools.lnx86/spectre/ahdlcmi/include -c InGaAs_NMOS_func.c -o obj/optimize/5.0/InGaAs_NMOS_func.o || rm -f -f obj/optimize/5.0/InGaAs_NMOS_func.o
InGaAs_NMOS_func.c: In function 'InGaAs_NMOS_AcLoad':
InGaAs_NMOS_func.c:3603: error: expected expression before ')' token
I put "***" to hide the exact paths as it doesn't change the situation.
What may cause a problem? What would you recommend me to do?
I would appreciate any advice.
Thanks.
boe
Re: Verilog-A compilation error
Reply #1 - Nov 24th, 2012, 11:06am
Deadok,
I think the message is clear enough:
Deadok wrote on Nov 23rd, 2012, 5:00am:
This is a tool bug. The compiler should never issue messages like this:
- B O E
Reply #2 - Nov 26th, 2012, 6:38am
It probably is a tool bug, but I suspect only so far as the compiler failed to detect a syntax error in your original Verilog-A code and report that.
Where did you get the Verilog-A model from?
Deadok
Reply #3 - Nov 29th, 2012, 6:23am
Hello!
The problem is still here. I got the model from Stanford:
http://nano.stanford.edu/model_iiiv.htm
Hope that will help.
How would you recommend to check the Verilog-A code?
Thanks.
Reply #4 - Nov 30th, 2012, 7:05am
Wow, that's really complicated code.  If I had to, I'd start commenting out sections of the code and see if I could narrow down the problem.  Eg, you could comment out the gate leakage stuff.
I've never seen a model with so many for loops!
