raja.cedt
hello, looks like some problem with simulator, try to change some parameter like rise,fall time little bit it may work. There is no problem with your code i ran the same and i got the following result. I guess it's not a problem with diode,otherwise it wouldn't gave correct result with sinusoidal. To make your self happy you could plot diode VI characteristics .
Have fun, Raj.
