Jul 17th, 2024, 11:29am
gm/id ocean script (Read 698 times)
grosser
gm/id ocean script
Dec 02nd, 2012, 12:32pm
Hola!
I would like to get some help with OCEAN scripts
I plot ID/(W/L) vs (gm/ID) and  want to run simulation for every gm/ID from 1 to max with step=1
I need to save Y value (ID/(W/L)) for every step.
I thought it'll work but doesn't
graph1=ocnYvsYplot(?wavex gm_id ?wavey id_over_W\L ?titleList '("simpleWave") ?colorList '(3))
ocnSetAttrib(?XScale 'linear ?YScale 'log ?stripNumber 2 ?yNumber 1)
idn=value(graph1 20)
when I check the value of idn it has 0.0 for every X value which is untrue of course.
when i type idn~>? i got
*Error* get/getq: first arg must be either symbol, list, defstruct or user type - 0.0
The question is how to return Y value of such a waveform ?
saludos
grosser
Re: gm/id ocean script
Reply #1 - Dec 3rd, 2012, 2:37pm
please forget the question. already solved.
Reply #2 - Dec 4th, 2012, 1:41am
Please describe the solution.
grosser
Reply #3 - Dec 10th, 2012, 11:00am
I did two X flips:
graph1=car(ocnYvsYplot(?wavex gm_id ?wavey id_over_W\L ?titleList '("simpleWave") ?colorList '(3)))
new=flip(graph1)
new1=flip(new)
and then
for(gm 1 gm_max
     idn_arr[gm]=value(new1 gm)
Now it works.
Don't ask me why, because I don't know. Maybe Andrew does and will explain that.
regards
