Sep 29th, 2026, 10:35am
Modelcard for the Verilog-A device (Read 2213 times)
Deadok
Dec 06th, 2012, 2:57am
Hello!
I have a trouble in passing parameters from the modelcard to the Verilog-A description of my device when I use Cadence.
To keep it simple let's have a look at the simplest resistor.
There is a single parameter there:
parameter real r=10 from [0:inf);
I create a modelcard for this resistor which looks like this:
simulator lang=spectre insensitive=yes
ahdl_include "resistor_tst.va"
subckt resist ( p n )
     resist ( p n ) rr
ends resist
model rr resistor_tst
+ r = 100
This model card (resist.scs) is included into ADE Model libraries.
The resistor is represented in my schematics by a symbol with the view name "spectre". The new component parameter was added in the CDF base layer:
Prompt: resistor_tst;
type: string;
Parse as CEL: yes;
In the simulation in formation for spectre I specified termOrder = p n.
The "otherParameters" = model.
That is the description of my setup.
Afterwards I run a DC analysis, but get a warning from spectre:
resist.scs" 13: rr: `r' is not a valid parameter for an instance of `resistor_tst'.  Ignored.
What would you recommend me to do?
I would like to use modelcards as as soon my problem is solved I will use the same solution for a simulation of a MOSFET.
Thanks for support!
Re: Modelcard for the Verilog-A device
Reply #1 - Dec 6th, 2012, 7:52am
You should contact Cadence support.  There is a special method they use to allow modelcards with Verilog-A models, but it may be proprietary.
