Jul 18th, 2024, 12:25am
Bug or nor not a bug in table_model (Read 1919 times)
RolfK
Dec 16th, 2012, 8:34am
Dear Experts,
I'm not sure if I run into a bug or did not understand the LRM.
SimVison gave me a very hard time (chrashed) before I could figure out the root cause. Please see belows test lines commented with OK or NG.
my table data is the same as in the LRM 2.3.1
# 2-D table model sample example
# y x f(x,y)
#y=0 isoline
	0.0 	1.0 	0.5
	0.0 	2.0 	1.0
	0.0 	3.0 	1.5
	0.0 	4.0 	2.0
	0.0 	5.0 	2.5
	0.0 	6.0 	3.0
#y=0.5 isoline
	0.5 	1.0 	1.0
	0.5 	3.0 	2.0
	0.5 	5.0 	3.0
#y=1.0 isoline
	1.0 	1.0 	1.5
	1.0 	2.0 	2.0
	1.0 	4.0 	3.0
My trial lines are below:
		// I(corePower) <+ ($table_model( 0.0  , V(corePower) , "../_ams_table_models/Test2d.dat"  )) ; // OK
		// I(corePower) <+ ($table_model( 0.0 , tPosOffsetTime , "../_ams_table_models/Test2d.dat"  )) ; //OK
		// I(corePower) <+ ($table_model( 1   , tPosOffsetTime , "../_ams_table_models/Test2d.dat"  )) ; // NG
		// I(corePower) <+ ($table_model( 1.0 , tPosOffsetTime , "../_ams_table_models/Test2d.dat"  )) ; // OK
		// I(corePower) <+ ($table_model( 0   , tPosOffsetTime , "../_ams_table_models/Test2d.dat"  )) ; // NG
It looks like if the isoline (first arg) is passed a integer string I run into problems. I have alos tested a variable as arg 1 which was defined as interger. This leads to the same fail.
The LRM says:
Quote:
4.2.1.2 Integer to real conversion
Implicit conversion shall take place when an expression is assigned to a real. Individual bits that are x or z in
the net or the variable shall be an error (see 7.3.2).
For a string integer this is may be not applicable, but if I pass a variable nad the function expects a real implicit conversion schould take place.
Could sameone confirm that this is really a bug and not a wrong usage of AMS by myself ?
Thanks a lot
RolfK
Re: Bug or nor not a bug in table_model
Reply #1 - Dec 17th, 2012, 8:03am
I agree with you that this is a bug in the simulator.
