Jul 16th, 2024, 3:45pm
Gain measurement using S21 and transient simulations using Cadence Spectre (Read 3333 times)
Sharath Raju
Dec 31st, 2012, 6:27pm
I am trying to measure the gain of a low noise amplifier designed using MOS technology in Cadence. The LNA is a made of an NMOS in common source configuration operating at 10 GHz (narrow-band). S-parameter simulations reveals the gain S21 to be 10.6 dB or 3.4 V/V.
I wanted to verify the gain value using transient simulations and replaced the input and output ports using "vsin in series with 50 ohm resistance" and a 50 ohm load resistance respectively. I applied a 1 mV amplitude, 10 GHz sine-wave at the input and see a 4.61 mV amplitude sine wave at the output, suggesting a gain of 4.61 V/V
Why is there a discrepancy between S-parameter and transient simulation. ? Am I missing something ?
Attached are the testbenches of the S-parameter and transient simulations.
Sharath
Sharath Raju
Re: Gain measurement using S21 and transient simulations using Cadence Spectre
Reply #1 - Jan 3rd, 2013, 1:21pm
Update: I solved the problem!
First off, I learned that there is more to the measurement of gain than simply measuring the S21. The following link talks about three different gains: transducer power gain, operating power gain and available power gain in the context of LNAs.
http://www.ek.isy.liu.se/courses/tsek03/SpectreRF_LNA533AN.pdf
I followed the above link and re-measured the gain. In the process, I discovered that I had made a few changes to the circuit in between measuring the S21 and transient gain! With the version inconsistency removed, I see an agreement between the values of operating power gain and transient gain  :)
Note: For those who are looking at the numbers in detail, my design does not have output impedance matching. Therefore the available power gain is negative  :o
« Last Edit: Jan 4th, 2013, 2:17am by Sharath Raju »
rfidea
Europe
Reply #2 - Jan 4th, 2013, 2:15am
Thank you for updating the thread! I read it from the beginning and thought the results was strange. What can I say, been there, done that (-:
