Aug 17th, 2024, 11:03am
disable task by event handler in same module (Read 1238 times)
RolfK
Jan 04th, 2013, 1:53pm
Dear Experts,
I run into a problem I,m not sure about. What I want to do is call a task by some event (always@(event)) and (as the task may be still executing) disable it before calling it again.
I think I need to execute the task inside a fork join block.
But this seems not to work. If the task is started once (evtDebug7 is seen) it will not be triggered again, even the event condition in the sourounding always block is matching.
always @( i_digital_core.evtClkSysTriggers_r[INST_INDEX] ) begin
	-> evtDebug7 ;
	disable  ccTiming ;  // The disable task does not work, don't know why. TASK IS BLOCKING ???!!!
	#1 ;  // just for trial
	fork    // Fork join did not help
		ccTiming( i_digital_core.valueClkSysTriggers[INST_INDEX] ) ;
	join
Hope someone can tell me to make this right.
Thanks a lot
RolfK
