Jul 18th, 2024, 4:26am
gmin or gdev in model using $simparam() (Read 1455 times)
Bob Atwell
Tucson, AZ
Jan 08th, 2013, 2:17pm
Does anyone have any experience using $simparam(gmin) or $simparam(gdev) in their models?  I am wondering exactly how these work in the case of gmin ramping homotopy and how much computational overhead they cost.  Should they be used in an initial_step or should they be used directly in a contribution statement?  Any help would be very welcome.
Thanks,  Bob.
Re: gmin or gdev in model using $simparam()
Reply #1 - Jan 9th, 2013, 6:56am
I've used $simparam(gmin, 1p), but usually in models where the look-up cost of this variable ought to be significantly less than the cost of the other expressions (exp).
Do you find that initial_step makes a difference?  I expect a good simulator to build a dependency tree and determine for itself what can be done during initialization.
Bob Atwell
Tucson, AZ
Reply #2 - Jan 10th, 2013, 5:57am
Thanks, but that doesn't really address my question.  Let me try to rephrase it.
I am trying to create a conductance branch inside a veriloga model that replicates or mimics the GMIN conductance used in the simulator primitives for both normal simulations and during a GMIN ramp homotopy.  This is the code that I think will do the job.
  @(initial_step) begin
     gmin = $simparam("gmin", 1e-12);
     gwiz = $simparam("gdev", gmin);
  I(p, n) <+ gwiz*V(p, n);
I have two questions:
  1. Will this code work correctly during GMIN ramping homotopy?
  2. Is there any sensible way that I can test it?
Reply #3 - Jan 11th, 2013, 7:48am
Since gmin ramping falls in to the black art area of convergence tricks, I don't think you'll have any simulator vendors posting clear answers in a public forum.  There's no guarantee, either, that the variable the simulator uses in that homotopy will be available for the user.  I think the LRM only says something like, if the variable is available/provided, then the simulator should use the recommended name.
However, you might be able to use $debug to print the value of gwiz during every iteration, and then stick your module in a circuit that requires the gmin homotopy.
Bob Atwell
Tucson, AZ
Reply #4 - Jan 11th, 2013, 11:34am
Thanks, the gmin seems to work everywhere I need it to and I'll try the $debug idea to check the gdev piece.
Thanks again. Bob.
