Since gmin ramping falls in to the black art area of convergence tricks, I don't think you'll have any simulator vendors posting clear answers in a public forum. There's no guarantee, either, that the variable the simulator uses in that homotopy will be available for the user. I think the LRM only says something like, if the variable is available/provided, then the simulator should use the recommended name.
However, you might be able to use $debug to print the value of gwiz during every iteration, and then stick your module in a circuit that requires the gmin homotopy.
