batmanbeginz
I am trying to simulate a simple 2 stage comparator in Cadence Spectre. However in the transient simulation, its taking a long time with warnings like mentioned below, and finally terminates the simulation:
" tran: time = 10.05 us (1 %), step = 15.63 ns (1.56 m%) tran: time = 10.05 us (1 %), step = 57.5 fs (5.75 n%) tran: time = 10.05 us (1 %), step = 7.019 as (702 f%)
Warning from spectre during transient analysis `tran'. WARNING (SPECTRE-16266): Error requirements were not satisfied because of convergence difficulties.
Error found by spectre during transient analysis `tran'. ERROR (SPECTRE-16384): Signal I(M1:d_s_flow) = 1.00277 GA exceeds the blowup limit for the quantity `I' which is (1 GA). It is likely that the circuit is unstable. If you really want signals this large, set the `blowup' parameter of this quantity to a larger value.
Analysis `tran' was terminated prematurely due to an error. finalTimeOP: writing operating point information to rawfile. "
I know this blow up is a common problem, still I am not able to bypass this. I introduced cmin=0.1fF still no luck. Also the current values are so low [I am using a verilog a based look up table based model] so that I am wondering how can it exceed GA ? The initial transistor sizing was also not that big to cause so much difference in current.
I relaunched with the attached netlist, but its taking hours to finish 1%. Normally it crashes at 22% of transient.
Can anyone help with this ?
Thanks and regards,
