BHL3302,
What exactly are you trying to do? It seems like the workaround being suggested is to use the corner to perform a sweep similar to your sweep: Corner 1 = 0C, Corner 2=20C etc. Since ADE XL can perform measurements across corners, you can then look for the reference voltage shift across corners. I forget the supported measurements, think at least min, max, and average are supported. If you want to do more complex testing, for example, test the temperature drift with trimming, then there is more work to do.
