Jul 18th, 2024, 3:37am
PSS and pac analysis on comparator with internal hysteresis (Read 2096 times)
avlsi
singapore
Feb 27th, 2013, 10:35pm
I need to simulate a GAIN of a comparator which has internal hysteresis.
when i run PSS and PAC analysis, i am getting an error.
Simulator: Spice3
Error: Floating point exeception.
How can i solve this error?
Winners never Quit,Quitters never Win
Re: PSS and pac analysis on comparator with internal hysteresis
Reply #1 - Mar 1st, 2013, 8:07am
The Spice3 I know doesn't support PSS nor PAC.  Are you really using Spice3?  Are you using a shooting method for PSS?  Can you try fixed-point iterations?  Can you have it do a long initial transient?  Do you have problems with transient?  If you run a really long transient, does it look like it's converging to a periodic steady-state?
avlsi
singapore
Reply #2 - Mar 5th, 2013, 4:38am
Thanks for the reply.
I could fix the problem as one of the input in the analysis window should be only a numerical value.
After the PSS and PAC successful run, how should i plot Gain versus time.
