Aug 17th, 2024, 4:15am
Converting integer to string in Verilog-A (Read 5658 times)
Deyan Levski
Mar 22nd, 2013, 2:25am
Hello everyone,
I am trying to create a "filewriter" block in Verilog-A which automatically generates a new file on every simulation run, for the purpose of some Monte Carlo simulations.
I can use the $random function, to generate a random integer, to be used for the unique file name for every run. However I can not figure out how to convert integer to string in Verilog-A. To illustrate, here is an excerpt of what I am trying to do:
parameter real vThreshold = 1.65 ;
//parameter string fileName = "fileName.txt";
parameter string filePath = "/tmp/";
string concat_var;
integer outputFileId;
string fcat;
analog
begin
     @(initial_step)
     begin
         fcat = $random;   // Apparently this is not allowed, how do I convert $random to string???
       concat_var = {filePath,fcat}; // Concatinate path and unique file name
         outputFileId = $fopen(concat_var); // Open a file in the specified path with the random name
     @ (cross(V(CLK) - vThreshold, 1)) // On rising edge of clock begin appending to file
     begin
        $fwrite(outputFileId, "%1.24f %f %f %f %f %f %f %f %f %f %f %f %f %f %f %f %f\n", $realtime, V(vIn[15]),V(vIn[14]),V(vIn[13]),V(vIn[12]),V(vIn[11]),V(vIn[10]),V(vIn[9]),V(vIn[8]),V(vIn[7]),V(vIn[6]),V(vIn[5]),V(vIn[4]),V(vIn[3]),V(vIn[2]),V(vIn[1]),V(vIn[0])     );
        $fflush(outputFileId);
It might be extremely simple and embarrasing asking such questions, but I was not able to find a solution over the net, nor the designer's guide manual to Verilog-A.
Deyan
Re: Converting integer to string in Verilog-A
Reply #1 - Mar 22nd, 2013, 7:25am
Is Code:
string fcat;
allowed in your simulator?  I think the Verilog-AMS language manual only says that string parameters are allowed.  Since strings are allowed in SystemVerilog, some simulators have probably allowed this functionality in Verilog-AMS.  In which case, you might be lucky and find that realtoa is available.
SV 1800-2009, section 6.16.15:
str.realtoa(r) stores the ASCII real representation of r into str (inverse of atoreal).
