Aug 20th, 2024, 4:08am
Get portOrder of one cell with skill (Read 7686 times)
Mar 23rd, 2013, 7:28am
Hi Guys,
I have a part of skill code that updates the pin orders in CDF. It needs to get portOrder of the cell first. But it fails to get portOrder with the code
cv~>portOrder
It returns nil if I type the code in CIW.
Please look at the complete code in the following.
procedure( CCSsetTermOrder(LIBRARY CELL)
let( (cv cellId cdfId pinList)
cellId=ddGetObj(LIBRARY CELL)
cv = dbOpenCellViewByType(LIBRARY CELL "symbol")
pinList=cv~>portOrder
almSetTerminalList(LIBRARY CELL pinList ?tool "auCdl")
) ;let
) ;proc
Is portOrder not valid for the symbol view?
Thanks in advance.
Yawei
Re: Get portOrder of one cell with skill
Reply #1 - Mar 23rd, 2013, 9:17am
That symbol has not the portOrder property if I type in cv~>prop~>name. It is so curious that it lost some important properties including portOrder.
I failed to export CDL of another cell because it lost the properties like 'lastSchematicExtraction' or 'syLastExtraction".
It reports the following ERROR message.
Quote:
Running Artist Hierarchical Netlisting ...
ERROR: Netlister: can't find the date library_name/cell_name/symbol was last extracted. None of the properties 'lastSchematicExtraction' or 'syLastExtraction' was found.
bernd
Munich/Germany
Reply #2 - Mar 26th, 2013, 4:27am
Shouldn't it be pinOrder and a cell property, rather than a portOrder and a cellview property.
Try schGetPinOrder(cvId).
* bernd
Just another lonesome cad guy
Reply #3 - Mar 26th, 2013, 6:27am
Hi Bernd,
It works。Thank you very much.
The following is my code.
;pinList=cv~>portOrder
pinList = schGetPinOrder(cv)
almSetTerminalList(LIBRARY CELL pinList ?tool "UltraSim")
almSetTerminalList(LIBRARY CELL pinList ?tool "auLvs")
almSetTerminalList(LIBRARY CELL pinList ?tool "cdsSpice")
almSetTerminalList(LIBRARY CELL pinList ?tool "hspiceD")
almSetTerminalList(LIBRARY CELL pinList ?tool "hspiceS")
almSetTerminalList(LIBRARY CELL pinList ?tool "spectre")
almSetTerminalList(LIBRARY CELL pinList ?tool "spectreS")
To my surprise, some cellviews has the portOrder property, but some cellviews has not that portOrder property. Anyway, your function works.
Best Regards
Yawei
Reply #4 - Mar 26th, 2013, 6:31am
ywguo wrote on Mar 23rd, 2013, 9:17am:
In my case, the CDL netlisting has nothing to do with term order in CDF. It caused by the lost of the above two properties, 'lastSchematicExtraction' or 'syLastExtraction'. I find a solution there http://www.cadence.com/community/forums/T/2859.aspx
opening the calibre view, and typing:
dbSetConnCurrent(cv=geGetEditCellView())
dbSave(cv)
--Yawei
