Jul 19th, 2024, 3:16am
Pages: 1 2
The oscillation of one high-pass filter and its loop gain (Read 17122 times)
Mar 30th, 2013, 7:23am
Hi Guys,
My high-pass filter begins to oscillate, but I cannot explain it in the Bode plot. May I have other simulation tool to find why it becomes non-stable.
The following picture is the output of the high-pass filter where it begins to oscillate.
Any comments are appreciated.
Yawei
Re: The oscillation of one high-pass filter and its loop gain
Reply #1 - Mar 30th, 2013, 7:26am
This is the loop gain acquired with stb analysis.
The phase margin is 58 degree and the unity gain frequency is more than 20MHz. The oscillation frequency is ~100MHz.
raja.cedt
Reply #2 - Mar 30th, 2013, 7:46am
Hello Ywguo,
You can't judge stability from bode, since you have non-monotonic Phase plot , use Nyquist to judge. Looks like you have some encirclements. Why don't you show schematic or try to plot Nyquist in cadence?
Regarding Oscillation Frequency i am not sure why it depends on UGB. May be Frank Wiedmann can explain better.
Raj.
Reply #3 - Mar 30th, 2013, 8:26pm
Hi Raj,
Thanks very much. I understand Bode plot is not enough for my case because the gain does not decreases monotonically. Plotting Nyquist is what I need. But I don't know how to plot it with Cadence tool.
Yawei
raja.cedt
Reply #4 - Mar 31st, 2013, 2:45am
hello,
plot real vs imaginary of the loop gain, this will give you half of the Nyquist plot means for +ve frequency's. Just imagine other symmetric half  if you want total Nyquist plot better export real and imag data into matlab and do some processing(but it is bit tricky).
But looks like you have serious problem with small signal approximation, because your oscillation magnitude is around 1V which can create large shift in the lop dynamics.
Raj.
Reply #5 - Apr 2nd, 2013, 5:47am
Hi Raj,
The oscillation magnitude is around 1 V because that is half of the opamp output. I have a divide-by-2 with resistors at the opamp output.
I read the section about Nyquist Stability Criterion in Oppenheim's book, Signals and Systems, Second Edition. It seems that I need to figure out if there is RHP poles of G(s)H(s). It states that the net number of counterclockwise encirclements of the point -1/K by the Nyquist plot of G(jw)H(jw) must equal the number of right-half-plane poles of G(s)H(s).
What can I do if it is hard to identify an analytical expression of the transfer function?
Yawei
raja.cedt
Reply #6 - Apr 2nd, 2013, 8:20am
dear Ywguo,
i think you don't need to calculate exact TF, very hard job for a transistor based problem. Nyquist criterion says
clockwise encirclements= closed loop RHP- openloop RHP. So please plot nyquist plot to check how many encirclements, based on your schematic you may guess open loop RHP, so now you can estimate stability.
Raj.
Reply #7 - Apr 2nd, 2013, 11:03pm
Hi Raj,
I run stb analysis and plot imaginary/real of the loop gain in the following picture. It encircles around (-1, j0) in clockwise direction. That is a regulator, stable. I do not see any RHP pole in Bode plot. What's wrong with my Nyquist plot?
Yawei
Reply #8 - Apr 2nd, 2013, 11:13pm
I zoom in the picture to show the plot near origin.
Reply #9 - Apr 2nd, 2013, 11:16pm
This is Bode plot.
raja.cedt
Reply #10 - Apr 3rd, 2013, 1:11am
hello ywguo,
you have one clockwise encirclement and there is no RHP in the open loop means 1 RHP in the closed loop(please refer my previous post).
Raj.
wave
Reply #11 - Apr 3rd, 2013, 6:20pm
Can you post a schematic and show where you break the loop for STB probe?
Perhaps you are not including all the FB paths.
AS
US
Reply #12 - Apr 10th, 2013, 2:08pm
Post the schematic. Seems like you have complex poles after the zero, there is a 180 phase shift around 40MHz.
From the looks of it this happens well below the 0dB gain, so system should be stable unless your not breaking
the loop correctly(you definitely have multiple loops or resonance happening).
Aman
Reply #13 - Apr 21st, 2013, 6:53pm
Hi Guys,
I am sorry to reply late. Here is the test bench. I ran stb analysis to plot Nyquist plot in the previous posts. I am sure this circuitry is stable. But why does its Nyquist plot look like there is one RHP pole in the close loop response?
Thank you.
Yawei
raja.cedt
Reply #14 - Apr 21st, 2013, 10:32pm
hello Ywaei,
this circuit is more or less a voltage regulator, why do you say it is high-pass, your transient results shows oscillations and Nyquist confirms it by having 1 closed RHP.
Raj.
Pages: 1 2
