Jul 18th, 2024, 10:34am
Load Resistance of Two-Port (Read 695 times)
oner
Apr 23rd, 2013, 5:07am
Hey, I m a beginner in Veriloga and new in this Forum.
I am trying to build an amplifier. My Problem is that the gain of the Amplifier is dependent on the load resistance.
I tried to set the output voltage (V(out) <+1) for getting the output current (r_load = V(out)/I(out)), but this gives me an error : "No DC convergence."
Can you give me an idea to solve this problem ?
boe
Re: Load Resistance of Two-Port
Reply #1 - Apr 24th, 2013, 2:39am
oner,
to get the voltage of a node, you do not need to have a contribute statement to this node.
- B O E
oner
Reply #2 - Apr 25th, 2013, 2:17am
Thanks for the reply.
I tried it with a current source and the problem is solved.
Oner
