Jul 18th, 2024, 12:37am
ahdl_include filePath (Read 2773 times)
spinfab
May 06th, 2013, 2:42am
In a spectre netlist, I would like to use
ahdl_include "absolutepath/file.va"
but instead using an absolute path, I would prefer to use an shell env variable.
Is somone know how to proceed with virtuoso-ADE?
Fab
Re: ahdl_include filePath
Reply #1 - May 6th, 2013, 10:44am
I don't think you can do it, where absolutepath is substituted inside a quoted string; most macro replacement does not apply inside quotes strings.
You might be able to
ahdl_include MYFILENAME
where MYFILENAME is defined somehow as "absolutepath/file.va"
The other possibility might be to
ahdl_include "file.va"
and have the search path set by the shell env variable.
Would either approach work for your situation?
spinfab
Reply #2 - May 7th, 2013, 12:52am
Thanks geoffrey for your advise.
nevertheless, what should be the env variable
regards,
Fab
