Hi AK,
It is not surprising that PSD rolls off at about 150MHz because the noise sources is injected in every nodes/branches as ideal Sample and Hold. Strictly, it is first-order sample and hold. So its PSD must be shaped by sinc function. Do you have Cadence application note Application Notes on Direct Time-Domain Noise Analysis using Virtuoso Spectre?
If you do NOT have that application note, please google the following Ph.D disseration. Low-Phase-Noise, Low-Timing-Jitter Design Techniques for Delay Cell Based VCOs and Frequency Synthesizers Todd C. Weigandt [1998]
He used similar method to investigate the VCO jitter. I recall that the principle is explained in the appendix.
Best Regards, Yawei
