Sep 17th, 2024, 1:25am
Delay Locked Loop Design (Read 3374 times)
saurabh3488
May 17th, 2013, 7:52am
Can Loop Filter in Delay locked loop cause stability issue.
Jeffrey987
Re: Delay Locked Loop Design
Reply #1 - Mar 12th, 2015, 11:08am
Typically a DLL is a first order type 1 system. You have to take into account that your phase detector is a sampled system and you are approximating a continuous s-domain system with a discrete z-domain system. Therefore your loop bandwidth should not be too large fref/10~20. This implies constrains on your loop cap in combination with Kvcdl and Icp.
